Evinrude Manufacture Date
bundy
"I was wondering if anyone can
"I was wondering if anyone can help identifing what year model of 40hp Evinrude motor for my old man. It has a Serial No. 03180964. It is an electric start with power trim and tilt from the 80's(approx.). The power trim and tilt motor won't work, so I want to find out what year model it is to chase down a good used one if I can.
Jeff."
"Need to know the model number
"Need to know the model number. It should be on a plate on the port side of the transom bracket along with that serial number. Can sometimes also be found on a core plug on the engine itself, but not always.
If from 1979 or the eighties it'll contain, if not start, E40 and the letters that follow will describe the model in detail including two which will give the year.
See http://www.skoterskroten.com/img/arsmodellstabell.pdf
for a full explanation of the codes.
The BRP Parts catalog also has year identifier and the facility to find what other models the same parts are used on. http://epc.brp.com/default.aspx?brands=ej&lang=e
The parts diagrams are useful too.
If the BRP site won't play ball then try
http://shop2.evinrude.com/ext/index.aspx?s1=bf6ad09c53cead335fcfd8a6471c0f7f"
