snookwheel
Hi Folks,
I have a 1998 4 cyl. Commercial Evinrude 100 HP engine. The Lower unit on the commercial engine is the same size as what is used on a V6 engine, which allows me to use a bigger prop than would fit on a standard/non-commercial 100HP engine's lower unit.
The engine is shot, but the lower unit is in good shape. I have a chance to pick up a 1995 non-commercial 130HP Johnson. My question is will I be able to swap the larger 1998 Commercial Lower unit onto the 19995 non commercial Johnson? They are both 25 inch shafts.
I use the engine to putt around on a Houseboat and turning a bigger prop is important to me. Many thanks, Scott
PS the 100 Commercial model is J100WP XEEC... I just checked the model look up info on this site and found out it is actually a Johnson. Wrong engine cover on it I guess...
