Screamin283
Model # 35524
Long story short, I have no spark. I replaced the points, condensers, coils, and ALL of the wiring in the engine, and in the boat. Gapped the points to 0.020". Coils adjusted on their bosses per the manual.
For testing purposes, I've been testing for spark using the pull starter and the engine wiring harness disconnected from the key switch harness at the plastic connector, and using an automotive style spark tester set to 7/16".
After doing all that, still no spark. So going more in depth, what I have found is that the points are shorted even when they are open (physically open). However, if you disconnect the wire from the coil to the points, (leaving the kill wire and condenser wire connected) this issue goes away. Disconnecting the black kill wires or the condenser wires from the points have no effect on the problem.
Again, on both sets of points, IF a coil is connected to them, they are electrically shorted when the points are physically open. This can't be right? They are, of course, also shorted when they are physically closed.
I checked for continuity in the coils, and I got 1.7k ohms between two leads and the spark plug...needle (?) where the spark plug wire installs. I'm not sure if this is a good measurement, and my manual doesn't have a specification on it. I've looked at a wiring diagram for my engine, and I have to believe its wired correctly.
So, any ideas or information is appreciated.
