flyfish2743
I am building a boat and plan to use the I-Command gauges. However, I like the Classic I-Command gauges because of the analog and digital readout. They were discontinued in 09.
The wiring is a little different than that of the fully digital gauges. The classic uses the Deutsch where the newer uses the quick connect linear wiring with the red connectors.
If I purchase the I-Command Classic gauges do you know of a simple connector for the gauge that will allow me to use the newer quick connect linear wiring instead of the older Deutsch wires?
Do you have any thoughts concerning the I-Command Classic vs. the I-Command fully digital?
Thanks in advance!
Thanks in advance!
