"I have twin 60hp e-tecs new i
"I have twin 60hp e-tecs new in 2006, the starboard started with intermittent starting problems, sometimes it wouldn't start or it would start and then not accelerate. Ran diagnostics software and no faults, checked spark, fuel pump, injectors with PC, swapped computers with good engine, no change. I can hear the fuel pump turn on and off and injectors clicking when I test with he PC. Fuel tanks higher than engine, filters new, fuel bulb is hard, tank is vented. Could this be a voltage isue? I heard that if the input voltage is even slightly off it won't run right...thoughts, ideas? Can I run injector cleaner through this engine?"
