Evinrude ETEC 50HP Outboard Steering Problem
raftsman
"The steering wheel and motor
"The steering wheel and motor are not inline. When the steering wheel is straight, the motor is off and the boat pulls to the right. It's not a hydraulic system and from what I can see, the rod is connected by two bolts. What do I need to do to adjust the alignment. I can't find any documentation and I really don't want to bring it to the dealer for such a small adjustment. Can someone please provide some feedback on the procedure.
Thanks"
If you have even turning radiu
If you have even turning radius to both sides then I would not worry about it. it is not a car and as long as you can go straight and turn to both sides you do not have a problem.
