Blackie323
Hi all and thanks in advance for any help i receive.
I was out on the boat at the weekend. Engine hadn't run for some time so took a bit to turn her over but got there in the end. The boat was running well, used for about 2 hours cruising around fishing. Then decided to do some water skiing. After about 30 mins of skiing the engine just bogged down and would only reach half speed if that. Seemed like i had lost a cylinder or maybe 2? the engine still runs just wont build up any decent speed or RPM. I had a brief look on the water and there was no obvious signs of loose bolts or cables on the coils or power packs. i'm wondering if im on the right track thinking it maybe a coil or powerpack failure just from working the old engine too hard? my plan is to run the engine and remove each spark plug boot to see if there is any change to hopefully workout if it is a cylinder missing. then ill move on to the powerpack if i need to. Is this a good place to start and if so is it normal for coils/powerpacks to just fail like this? I am learning as i go with outboards, recently doing gear oil and water pump myself to save money.
Thanks again.
Sam
Thanks again.
Sam
