Evinrude E3RCCM Recoil Starter question
Bullie
I think the recoil spring is broken on this little Evinrude. The throttle cable goes right over the top of the screw I need to remove to get the spring out. I don't see anything I can loosen to take the push cable off. Help.
In case this question pops up again. You remove the throttle cable from the motor end and remove the fasteners on the recoil starter then turn the starter counter clockwise to unscrew the throttle cable from the slide.
