Evinrude E150FSLSIF RAM 2001
You might obtain a response if
You might obtain a response if you list your problem in detail. I retired before that engine was manufactured BUT there are others here who I'm sure are knowledageable of it.
Strange... I saw JWB's name listed on this post previously but no reply was listed. Wonder how that took place.
"Joe, Andrew just did a system
"Joe, Andrew just did a system back-up (or something technical like that), so maybe got eaten
"the ffi's are axctually o
"the ffi's are axctually omc till about 02 then brp took over & by 03 the bug's (if u will)were worked out.(sorta)by 03 thru 05 brp called them di's (same thing as ffi)I here the pro's & con's on these engines repeatedly. If fact we got a pair of 175/04/di's 2day. port bank ctr cyl wasted. u have a emm that gives codes. hard faults,(whats happening NOW)is the PRIMARY concern. u can learn alot about your engine thru your software program which is available 2 u just have 2 know what your looking at or leave it 2 a tech spec. 90% of your problems can b found thru your emm diagnostic software u just have 2 do alittle more babysitting then usual w/ these engines/thru your software 2 stay on top especially any ffi prior 2 03. JZMarine"
