hi i have a 140 evinrude vro w
hi i have a 140 evinrude vro when the motor is idling at the dock its ruinng on all cylinders when i go out and go pass half throttle the #1 cylinder will cut out this problem was jumping around and now is staying at the #1 it was #3 then went to #4 now staying at #1 i changed all coils rebuilt the carbs checked the reeds new plugs and wires head gasket power pack and compression is 150 in all four I neeeeeeeeed help!!!!!!!!! cant figure this out could this be a bad timer base. the motor has very strong spark but just drops random cylinders ALSO once in a while whlie running at wot with 3 cylinders the forth cylinder will kick in for a minute then cut ALSO at idle the motor will slowly drop its rpms till it dies some times. PLEASE HELP anybody thanks!!!!!!!!!
