T
thomjw
Guest
" Help Joe,
yesterday my 1985
" Help Joe,
yesterday my 1985 evinrude 235 v-6 vro stalled and then backfired when I tried to re-start. Now all it will do is backfire (thru exhaust not carb)when I try to start it. I cleaned the plugs (nearly new)emptied out the gas and re-filled, cleaned out the gas filter. (even tried starting fluid) I have spark at all the plugs. The compression is exactly the same on all cylinders. It is acting like a car that has jumped timing. I know a 2-stroke can't do that, but that is the symptom. I checked the timing with all the plugs out and cranked it. It read TDC. I manually held open the advance thing against the stop and cranked it and it read 20 degrees. I'm stumped! This was the first time I had it out this year. It ran fine for about 30 minutes, and while trying to pull it toward shore to trailer it, it stalled and now nothing will get it to start. Is it possible that the electronic ignition is bad even though the spark is there? "
yesterday my 1985
" Help Joe,
