Evinrude 99 1986 not running well
L
LEE.D
Guest
"today iput down my boat. it r
"today iput down my boat. it ran great on idling but when i came to the point i had to give it full throttle it couldnt get it really ran slow . everything is new water pump .fuel pump, spark plugs. cleaned carb and gave it a kit aswell.and by the way i used alot of fuel. am sure its using alot because it smoking alot aswell. and its not coming from the oil cause i got it back down to 1:100 ratio.the spark is good aswell. can any one help please. thanks alot."
"spark test,..compression test
"spark test,..compression test,..all good,look at fuel delivery,..fuel tank,fuel line and bulb,..connectors on line,..vent on fuel tank,..bad fuel pump,..dirty or mis adjusted carb..,linkage,timer base problems."
Just took the 100:1 sticker of
Just took the 100:1 sticker off a motor today.That is a mistake to run at 100:1.Check compression and check the spark on each cylinder.
