Evinrude 90 hp V4
bandit01
How can I find the year of my
How can I find the year of my motor? a bolt when it turned has messed up some of the model mumbers up all I can see is E9 COS. I need to get the number on the type of trim box my boat uses so I can get another one. the boat is a 1982 BMC 16'
serial number on the motor is J0563904. If anyone can help I appreciate.
Mike
"There may be a small core plu
"There may be a small core plug (looks like a small freeze out plug) on the powerhead with the model number on it. However, the "CO" in the model number would indicate a 1985 model."
"Usually, on the V4, it would
"Usually, on the V4, it would be located on top of the powerhead near the port (left) cylinder head gasket."
"Joe,
The model number on th
"Joe,
The model number on the 90 V4 Eveinrude motor is E90MLCOS and If I'm not mistaken someone has probably put this trim on this motor themselves
the trim solenoid relay is a 12V 20/30A Bosch
5-prong so would a VF-15F21-Z11 # 586224 made bt tyco work in their place? Mike"
"Mike..... Model E90MLCOS indi
"Mike..... Model E90MLCOS indicates the engine is a 1985 90hp Evinrude. This engine comes equipped with PTT.
The trim relays are part number (original, superseded, and final numbers) are: 582473 - 582472 - 584416 - 586147 and finally 586224. (About $20.00 each)
(Your statement here) = trim solenoid relay is a 12V 20/30A Bosch. 5-prong so would a VF-15F21-Z11 # 586224 made by tyco work in their place?
I have no idea about the Tyco numbers.
I have a few relays left if you can't locate them on this site."
