DBiasii450
Im new to outboards and am having a problems with my 1996 evinrude 9.9. I just picked up a new boat with it on and at WOT it bogs down and barely builds rpm. when you back off the throttle it starts to pick up a little speed but still maxes out my 15ft sea nymph at 8mph, I knew something was wrong because my friends mercury 9.9 with the 15hp conversion will push his 17ft at 14.5mph. So far I have cleaned the carb (15hp carb), checked and cleaned the fuel pump, replaced fuel fittings, done a link and sync, changed spark plugs, and a few other small things like fresh gas/ sea foam etc... the motor also seems to have a hard time idling even after setting the adjustment to its best running setting. once in the water it likes to stall out when put into gear from the added resistance of the water. The motor also seems to surge, it is most noticeable when im only at about 1/4 throttle.
Ive done some tests while at WOT like pumping the primer bulb and pushing the choke on with no change at all. i have also pulled off each spark plug wire while it was idling at home to make sure I didn't have a dead cylinder, everything checked out ok so far. Im pretty stumped now so any help is greatly appreciated. i just want to get out and enjoy this thing without worrying about getting stranded on the lake.
