DBiasii450
So if you check my other thread you can see the problems I was having with my 9.9 but I was able to get it running to the point were the speed of the boat was acceptable, so I delt with it. I still was not getting full throttle performance, but it was ok after I installed a hydrofoil. well today I took the boat out and as I left the dock and got out of the no wake zone I floored it, took off great and got up on a plane and then my water pump buzzer started to sound (has done this before). it is obviously pumping water just fine as there is a steady stream coming from the motor. about 10 seconds into the buzzer ringing the engine seemed to go into a limp mode and it dropped the rpm off by itself and went down to about half throttle (without any movement of the throttle lever) . It ran this way for the rest of the day, could this be a CDI problem? I also have problems keeping the motor idling after I shut it off and try to restart it when its warm. any help is appreciated, Im getting pretty fed up with this thing.
motor is a 1996 evinrude 9.9 with a 15 hp carb
