Bluewaterjunkie
I have a Evinrude E8SRLECA98, it is a Yacht long shaft that powers my small yacht. 2 stroke, two cylinder 1998 edition, little used, looks like a new motor.
I recently obtained it with the vessel & I have fixed a number of issues. However the last issue is the most problematic for me and I can not find the cause.
The motor starts easily, but runs rough, like it was running only on one cylinder. It does this at all revs though it is worse when the throttle is twisted.
I have pulled the plugs out & replaced them with spares, just in case. Then I checked there was a spark at each plug when the motor is turned over, plenty of nice bright blue spark (& it gave me a good shock when I grabbed the wrong area of the motor in the process). Then I tested the compression and both cyclinders are of equal compression.
I hope that has ruled out a single cyclinder as the cause ?
The only other things I can think of is the carby/fuel or the timing of the spark ?
Where should I look next ?
