lonewolf15006
"my drive shaft broke in lower
"my drive shaft broke in lower unit at pinion bearing ,appears pinion bearing went dry from low oil level in unit, all gears and other parts look good ,lower unit seals and impeller needs to be replaced while i have it apart,bought it from a friend and other than that it runs fine.where do you measure shaft to determine if it is a 20 ,0r 25 inch shaft,when i measure mine from pinion nut end to top end it measures 32 inches"
