Evinrude 75 hp ; 1978 Wiring Problems , Engine wont shut down
JeanArr
After rebuilding the entire engine we fired it up and everything runs perfectly but when turning the key the engine wont shut down.
Can some one explain the wiring or has a diagram?
(Ignition Kill Circuit)
(J. Reeves)
A Black wire (ground) should lead from the powerhead to the powerpack. There will also be a Black/Yellow wire leading from the powerpack to a raised "M" terminal of the ignition switch. To complete the circuit, there will be a Black wire from the other "M" terminal of the ignition switch to ground.
When the key is in the OFF position = The two "M" terminals are connected,. effectively shorting/killing the ignition.
When the key in ON position = The two "M" terminals are not connected and the ignition is engaged.
Thousands of parts in my remaining stock. Not able to list them all. Let me know what you need and I'll look it up for you. Visit my eBay auction at
