Evinrude 75 Fleetwin
  • Thread starter Pennyslvania Newt
  • Start date
P
Pennyslvania Newt
Guest
I just got an Evinrude 7.5 Fle
I just got an Evinrude 7.5 Fleetwin and am trying to find a shop manual and owner manual for it. I have several questions though
1) Serial Number 7522-18925 What year is it?
2) Where can I get an owners manual and shop manual
3) I have a two line gas tank that is a little rusty inside and it will not prime up so where can I get parts and does somebody make a plastic tank for it
The motor looks to be in very good shape is complete and has all the deacls and emblems etc. on it so I think she has great possibilities
Pennsylvania Newt
"1) Your motor is a 1957.
2) http://www.marineengine.com/parts/parts.php?Year=1957&HP=7.5&Model=7522
3) You won't find a plastic tank that is suitable for your 2-line pressure system. There are parts available to fix the connectors at http://www.laingsoutboards.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=LO& Category_Code=NP1b and http://www.vintageoutboard.com/(as well as a lot of other places).
You can also convert your motor to using a single line tank. One good link is http://www.outboard-boat-motor-repair.com/Johnson/Pressureized%20Fuel%20Tanks.ht m
You could then use a cheap plastic tank to run your motor.
Good luck."
On the 7.5 (I think) h
On the 7.5 (I think) he can get a pump and mount it to the cylinder. Makes for a neater installation. I did it to my 35.
sb
