"I have discussed this motor o
"I have discussed this motor on here before. Need more info. It is a model #60173C, took it to the local Evinrude shop because it had not been in the water in a few years. Mechanic said he cranked it, left it running while he went to get some tools, got back to it, it had cut off and would not restart. Checked it out and the part is an electrical item under the flywheel, appx. $450.00, and when the flywheel is removed, it may cause other electrical problems and he would not recommend fixing it. My problem is this motor was rebuilt about 10 years ago with all internal parts replaced by a Johnson mechanic, only between 50-60 hrs. on it now.
I am wondering if maybe the water pump is bad and it maybe overheated and shutdown."
