Evinrude 70hp 2 cycle!!!!! 1982
emmetdoc
- How to Remove heat sender unit from Evinrude 70HP Engine?!!!!
- How to test if sender is good, only one tan wire attached, no gauges, No alarm fitted
Heat sender unit is not connected to any source of power... completely disconnected....... Can I test sender in Engine without removing it from engine and how to do test as i don't know if sender is good or faulty?
looking for information On Evinrude 70 HP.....Red Purple wire connected to push button starter also red yellow wire connected to push button starter going to starter solenoid... does the Red Yellow wire need to be earthed?
NO absolutely not. You would have a direct short to ground every time you pressed the start button.
