Small Peru
Hi,
I have a 1988 Evinrude 65hp Commercial outboard engine and I want to change the fuel assembly (Part #398399) because the plastic part of the pump broke off the original.
The problem I'm having is finding a new pump that is identical to the one I have.
I purchased a new pump (jobber part #438557 or similar) but the back side of the pump has a hole in the middle (between the two screws that hold the pump to the engine) that is open where as the original the middle hole is not open. (See images)
I was wondering if I could install the jobber, with open hole, and not have it impact the performance of the pump since there is not hole in the engine at that location which means that hole would be either be, sucking or pushing, outside air. (I'm not quite sure what the hole is used for)
Thanks!
Thanks!
