Web-Footed Flyer
Hi, to All of You.
As suspected, I am new to this forum, I would and will appreciate any help for anyone. As the title says I am looking for the above mentionned informations.
This motor has run flawlessly since 1986, changed the plugs twice only, in all these years. Last month coming at the end of a 15 minutes run at full speed (open throttle), it died on me, when I reduced the throttle..... It started up again but would not run at slow speed (throttle).... would run at full throttle for a short period (30 seconds) only. Opened the engine cover : the inside of cover and engine were covered with heavy black oily film (suspect a powerhead gasket leak).
I will need to dismantle this motor, hence the need for a shop manual..... ( I allready have the Seloc manual for 1 & 2 cylinder outboards 1973-89, it does not provide the information, this manual is for recreational engines only)
I thank you in advance for any help you may provide.
Regards
Web-Footed Flyer
Regards
Web-Footed Flyer
