Evinrude 50hp 1972 repost
G
Gordon Youd
Guest
" Evinrude 50hp 1972 tune up
MarineEngine.com Message Board: Outboard motors: Evinrude 50hp 1972 tune up
By Gordon Youd on Sunday, May 02, 2004 - 12:57 pm: Edit
Hi, Joe, Can you give me some help with tune-up of this beast? please.
Model 502273C, electric shift.
There are timing marks on the flywheel, I have a timing light would it help to check this, I may have undone the wrong screws when trying to set the motor for slow revs.
Regards, Gordon.
By sparky on Sunday, May 02, 2004 - 05:46 pm: Edit
The timing is fixed and should not need to be adjusted.Do a compression test and post the results.
By Gordon Youd on Wednesday, May 05, 2004 - 01:46 pm: Edit
Thanks for your feedback sparky.
The question was about the settings, I adjusted the rod that goes to the throttle cam yoke because I could not get the motor to run slow.
I found out later the throttle cable was not coming all the way back.
That was the reason for asking about the timing/settings.
Hope you understand my ramblings.
Kind regards, Gordon. "
"The cam scribe mark should al
"The cam scribe mark should align with the center of the roller at 3° +/- 1°.
Now you know why measurments, notes, and pictures should be taken (grin) before one changes something.
Joe
" Thanks Joe, I deserve that.
I have sent for a manual from USA.
Many thanks for your help.
Gordon. "
