I have a 1960 5.5hp (5520) fisherman that has a low spark and will not start.
I replaced the coils, condensers, points and spark plug wires.
I set the timing with an ohm meter.
I have 1 ohm across the primary coil and 8.5K ohm from the secondary winding wire to the stud where the wire connects.
When installing the wires I have 8.5k ohm from the secondary winding wire to the end of the spark plug wire also.
Using a spark gap tester, I am getting about a 1/8" spark on both spark plug wires. I don't know what else I can do to increase the spark.
Any suggestions?
Any suggestions?
