thudpucker
I have this little guy. It pulls through with good compression.
The plugs are never Wet!
There is fire to the plugs.
The fuel line pump from the tank will drive the fuel all the way to the Carb.
When we pull it through, the plugs don't get wet.
It does not fire when I spray Carb Cleaner in to the carb.
I don't think the Fuel pump is pumping much as we pull it through.
I'm wondering if there is one single problem or two.
If the Key is sheared, I think it could cause all this.
Look at the Fuel pump in the photo. Is that the correct Pump? It sure is a large one. Bigger than the one on my Six Hp Johnson.
![Fuel pump.jpg Fuel pump.jpg](https://www.marineengine.com/boat-forum/data/attachments/3/3878-aa9fb14ec732c425c7333ca1d1fe5e9f.jpg)
![Evinrude numbers.jpg Evinrude numbers.jpg](https://www.marineengine.com/boat-forum/data/attachments/2/2475-5b1934dc3c81fb122d511981c08f34e5.jpg)
![DSCF6081.jpg DSCF6081.jpg](https://www.marineengine.com/boat-forum/data/attachments/2/2466-f46f2dbabfae44ee61dc59d07abb7176.jpg)
