Evinrude 4hp points gap what size please
roopzz
hi
i have an Evinrude 4hp o
hi
i have an Evinrude 4hp outboard
can anyone tell me what the gap for the points should be please?
thanks
They can be set to fire at 180
They can be set to fire at 180 degrees using the timing marks on the flywheel and magplate for peak performace of the magneto.For the average person setting them at 0.020" is OK.
"(Point Setting Of Magnet
"(Point Setting Of Magneto Models)
(J. Reeves)
Set the points as follows. Have the flywheel key aligned with the fiber rubber portion of the ignition points. Adjust the gap so that a .020 gauge will pass thru but a .022 will not. Should there be any question of the points being dirty (touching the contact with your finger would cause them to be dirty), clean them with a small brush and acetone or lacquer thinner.
NOTE: Should the operating cam have a small portion on it with the word "SET" imprinted, align this portion with the fiber rubbing portion instead of the flywheel key.
When time permits, visit my store at: http://stores.ebay.com/Evinrude-Johnson-Outboard-Parts-etc?refid=store"
"1968 3-4hp powerhead swap: I
"1968 3-4hp powerhead swap: I have a 1968 jw23a 3hp. that runs very well despite only 70&75 psi compression. I also have a 1976 4hp powerhead mod.4r76m that I am considering to swap with the 3hp after a rebuild. I`m not sure but it apears the hp. increase, if there is one, is in the induction and exhaust, not displacement. What I would like to know is am I going to run into complications with the compatibility of these two powerheads. Water pickup, using the inner exhaust tube,or whatever else."
"As long as the powerhead to a
"As long as the powerhead to adapter plate or exhaust housing matches up, you should encounter no problems. The mating gasket should tell the tale."
