Hi All
Just joined after a referral from another site
Have a question I wonder if you can help me with.
I am in the process refurbing my little evinrude 4 1984 and have run into a problem putting the impellor on the drive shaft, I can not
for the life of me figure out what makes it turn!
I have a notch in the impellor and a flat spot on the drive shaft, but the
two do not seem to augment each other in any way and the impellor can just
spin.
I am sure i am missing something obvious here.....
I wonder if you guys have any advice as I dont want to fiddle with the clutch,
and coolant pipe just to find the impellor does not turn
At the moment if I put it all together the driveshaft seems to just spin
inside the pump housing not 'catching; the impellor.
I hope you understand the question and this isnt all gibberish as a result
of working too much and not remembering something obvious! I should have kept in one piece until it came to putting it back together
Thank you
Mark
spin.
Thank you
Mark
