stantheman55
I have a 1991 Evinrude 48 spl on a 20 ft poontoom boat and I have a idle problem boat will run fine once you get it started I have cleaned the carbs and seen no trash but I cleaned them and put back on. I also checked the comp and had 115 psi on the top but only 80 psi on the bottom as I said boat run good mid range and full throttle but it WILL NOT IDLE. and in my opinion it uses way to much fuel for a 48 hp what could be my problem and how do you adjust the IDle any help would be greatly appreciated thanks stan the man
