"I have a 1995 Evinrude 48 spe
"I have a 1995 Evinrude 48 special that has been running fine until recently.
Motor runs well. No stalling or rough idling so I don't think it is a fuel/air problem. When the throttle is taken out of gear the motor revs fully (full rpms) as normal. When in gear the the motor only seems to run at 1/2 throttle (1/2 rpms) when the throttle shifter is fully pushed. The reving (rpms) do not stop at half but only reach half at full throttle. I do not have an rpm gauge.
The prop is dinged but not really that bad.
Did not get to check the oil in the foot of the outboard
Water temp was 57 degrees so I don't think the oil is too thick (cold)
The water it was peeing wasn't even warm. Is that normal?
Thanks,
TJ"
Thanks,
TJ"
