W
whaler_pr
Guest
"Hi everyone! Im trying again
"Hi everyone! Im trying again to tune my engine "1986 40hp" and unable to hit the nail. The engine at full throttle runs great but when going slow or mid, the engine runs rough, I suspect the problem is adjustments between carbs and ignition plate "I think". What is the timing for idle?? 4 degrees? I think this should be done to proceed with the other adjustments. In water, I pulled off the cover and when going at mid revs, I manually opened more the carbs in the linkage and it runs clean but the cam is about one inch behind the carb linkage, does the cam needs advance? please help me here!! If someone here still have service manual regarding this tuning section please send me a copy to [email protected] Thanks!!!"
