Evinrude 2018 E-Tec power trim
Beauxti
Just a soapbox issue: I just replaced the top seal on the single-ram power trim unit (approx. $250). It is painfully obvious the design engineer was never required to fix one of these units.
First, the glaring issue: the damn fill plug on the left side of the reservoir is partially covered by the attachment frame and is only really accessible with the trim fully up.
Second, when accessible, the fill hole is small and horizontal, so filling it requires squeezing as much fluid as you can, and only half of it makes it in.
Third, when removing the unit, the power unit wires are short and there's no option to disconnect them without going through the main engine housing, unless you cut the wires and add your own connections.
Fourth, due to the single-ram rod design, I'm betting the top cap seal will need replacement in a few years because of the pressure required to lift a 115 solely by that single rod.
Fifth, none of the three "Evinrude" authorized dealers were enthusiastic about taking on this kind of work, meaning it's a six-week wait and over $400 for labor.
I mean, WTF? Are outboard motors always like this? It seems like this would have been corrected 40 years ago.
Thanks for listening to my bitching. I'm sure there will be a ton of comments on how wrong I am and how great this stuff is. This is just my opinion after getting the job done.
