Evinrude 1997 BE50RLECR
chrissvv
"Hi, On the transom bracket th
"Hi, On the transom bracket there is a wire that has become disconnected at one end.Parts listing has it discribed as "0582499 LEAD AY,BONDING" Where does it connect to??The end that has come loose is just open wire(no fitting or connect on the end)"
"that is a bonding wire,to ret
"that is a bonding wire,to retain continuity between sections.it is necc to help w/corrosion.look real close,u should be able to see where it connects."
"I've now taken the motor
"I've now taken the motor off the boat. I'm still lost as to where this lead goes. The only place that it looked like it may goto is the gas assist tilt housing, There is a threaded hole but due to this housing being replaced not long ago I cant tell if this is the correct place. Is there anywhere I could get the info .
Cheers Chris"
"On PT models it goes to one o
"On PT models it goes to one of the screws holding the electric motor, on the Touch-trim models it goes to the touch-trim unit."
