jasoncmu24
Hi gang! good to see everyone here. Maybe someone can help me here. I have an eninrude 25 hp motor that won't turn over. So, I started with fuel, it's ok. Checked the plugs, and no spark. So, I went back to the coil packs to see if I get spark to it. I placed a screwdriver in the plug and moved it close to the engine block to see if I get a spark. Is that they right way to check it?
I want to see if I'm getting anything from the ignition module. Is there a way I can test the ignition module on this? I'm open for some ideas. I have it pretty much narrowed down to the coil packs or ignition module, I just need to find a way to confirm it. Once I know which is causing me a headache I can quickly replace the part.
I'm anxious to get this fixed, I have some Walleye fishing to do on Lake St. Clair in Michigan! (I heard they are tearing them up in places! augh!)
