Evinrude 1990 115 hp vro problem
kuri
"Hi, i have a problem i read a
"Hi, i have a problem i read a lot of change the vro pum, for what kind of pump can i changed?
because i bought a 1990 115 hp evinrude vro
and has a broken vro pum so if i can replaced for a difrent kind cheaper thanks"
welcome to marineengine!!
y
you could just plug the oil side.....and disconnect the wires
if you do away with the vro you sill have to pre-mix your gas at 50:1..........and as jwb pointed out in another thread you will need to purge the fuel lines to rid the un-oiled fuel.
