Evinrude 1987 140 v4 Looper recirculation hose hookup
N
nymack66
Guest
"Can any one please confirmed
"Can any one please confirmed my recirculation hoses connection ?
Please see the pictures below I simply cannot trust the previous owner at this point for anything.
From the bottom (lower bearing) 1 inch length hose to a T with a check valve connecting up to the Top bearing housing (larger hose)
The little T piece (smaller hose) splits over to the lower intake (cyl 4) and again connected to plain T valve (smaller hose) one side of the T is connected to the check valve on the #4 Cyl the other end of the T connects to nipple on the block #3 Cyl
Number 3 intake connects from check valve directly to #4 Cyl nipple
Number 2 intake connects from check valve directly to #1 Cyl nipple
Number 1 intake connects from check valve directly to #2 Cyl nipple
Reason for me asking the manual shows nothing in regards to the correct connections can some one compare it please ?
Look carefully you can see the blue tie wraps to the check valves
Picture One
url]
Picture 2
url]
url]
"r u using,..a FACTORY,service
"r u using,..a FACTORY,service manual...or clymers/seloc....its in the back,..of the factory one,as well as port/starboard reference pix,wiring diagrams,..etc."
"I have both, the factory manu
"I have both, the factory manual does not even mention the hoses, as for the Seloc it shows the hoses but fail to show the connections."
