History,
Carburetor rebuild kit installed and external tank “is” feeding fuel to the carburetor
Replace coils, points, condensers, and plugs - have a good spark
Fuel pump rebuild kit installed “correctly”!
New reed valve assembly installed
Replaced “all” crankcase gaskets and crankshaft seals
Re-ringed pistons and honed cylinders – compression is 105, 110 turning over with a drill motor and can pull a vacuum on the case now where I was unable to before.
Engine parts diagram shows two metering rods – these where not replaced
The kicker is there is “NO” felt suction through the carburetor – therefore no air/fuel being drawn into the crankcase.
Tried the little gas in the spark holes trick.
[FONT="]Many thanks and any help would be appreciated[/FONT]
