gnshowzaolcom
Hello again, and thanks for help in the past. Worked on this rescue motor as an educational project (I had/have no mechanical skills/knowledge). Replaced ignition components, rebuilt the carb, replaced the impeller, cleaned up the manifold, etc. Cranked it and it scared me...started right up! Bad news...gearcase is leaking oil through a small hole in the back...my 1956 5.5 Fisherman has the same hole. Do you think this is a junk housing? Or, are there seals/gaskets to be replaced? I did not find any info on rebuilding the gearcase or replacing parts in the information I had. Thanks agsain for your patience and input.
Regards,
Vic
Regards,
Vic
