I have an Evinrude 150 two stroke that will run fine when started, run at any speed as long as you want but drop back to idle and it will sputter and quit
This is what I have done
All new gas
complete overhaul of all six carbs
I had a outboard shop run all the tests on the ignition system, all OK
overhaul of fuel pump
blocked oil VRO and put oil into the gas
I have tried squeezing the bulb has no effect, bulb is hard.
This is the exact problem I had when I started and I have gained nothing from the changes I made.
I checked the gas line from the tank to the engine, good gas flow
After it sputters and dies, it will not restart and idle, but if I can get it to just sputter a second I can speed up the engine and we can
get home with no problems, runs great, until you try to idle and get on the trailer....lots of fun...
What am I missing??
All new gas
What am I missing??
