"My 115HP Evinrude has a vro/f
"My 115HP Evinrude has a vro/fuel pump which I believe has failed. The engine stopped running while trolling. It kept starting but would not continue running unless I continually squeezed the fuel priming bulb. Continuing to squeeze the fuel priming bulb enabled me to get back to the dock at low speed. By the way the warning horn
went on and off going back to the dock. I checked the fuel connections, fuel filters and fuel lines
and they are all OK. How can I check the VRO/fuel
pump to make sure that's the problem and if so can I just install a fuel only pump and mix oil-gasoline in the tank? Can the VRO/Fuel pump be repaired? The price of a new one is very expensive. Any suggestions would be greatly appreciated."
