Evinrude 115 HELP
95cajun
"I just bought a boat with an
"I just bought a boat with an Evinrude 115 outboard on it I think?!?! Model on the bracket is 115999R S/N J0002087 The block has numbers on it also the middle of the motor behind the flywheel is 396 244 (bigger letters) 1 IK23 Then on the left side clinder near freeze plug is FL2784 the cylinder and the block or intake are stamped 9604. Any info on this motor would be helpful. known facts : It is a 4 Cylinder non VRO, the cover says its a evinrude 115 the Mounting bracket is from a 1978 135 HP (I really hope this is right)"
If you go back to the main pag
If you go back to the main page there is a line that says Johnson and Evinrude parts. Then go to the middle of the page on the right side and look for modle number guides. This should give you the codes to tell you what you have
"Thanks, I don't really tr
"Thanks, I don't really trust the model & serial on this engine and I need to see if the numbers stamped on the block match the tag."
