Evinrude 115 b95 model Vro wiring connection
houk27
"Hello Y'all,
Okay I figu
"Hello Y'all,
Okay I figured out my motor is a '95. I have it running fine. When I originally set it up I just ran the oil in the tank for the gas. Well the buzzer annoyed me so I am bidding on a oil tank on eBay. The only problem I am having is to what wires do I hook the level wires from the tank to the engine. I can't seem to find any spare connectors. The only thing that I can find is a tan and black wire that are near the main big red round connector. I haven't received the oil tank yet so I am clueless as to what color the wires are. I know y'all can help. Thanks, Tony"
"That's the wires Tony. On
"That's the wires Tony. One tank wire connects to ground, the other to that tan wire."
"Thanks Joe. I bought a oil ta
"Thanks Joe. I bought a oil tank off of a guy on eBay. I just wanted to make sure that those two wires were the wires to hook the warning system up to. I appreciate yours and all the other peoples help on here. Thanks again, Tony"
"Notice that the tank wires ar
"Notice that the tank wires are slightly different. One is usually completely smooth, the other has a somewhat design. It matters which one goes where but frankly I forget just what the different is.
If one has a ground, bolt thru fitting (grd), and the other has a knife connection, then the connection is obvious. Otherwise, hopefully, someone will jump in here with the proper setup."
"Joe,
I was speaking to the g
"Joe,
I was speaking to the guy that is selling me the tank. He said the the operation of the warning is just a closing of the connection. If that is true then it should not matter since either wire would complete the connection through the circuit. I will hopefully get a wire bundle that has one brown and one black. Question for you, how do you know all this stuff? Thanks again, Tony"
"It's not a simple contact
"It's not a simple contact closure. There is a small amount of circuitry build into the sender on the tank. This activates the horn for the chirp every 2 minutes. If it were a simple contact closure, the horn would sound continuously."
"Dcramer,
Thanks for the info
"Dcramer,
Thanks for the info. I hope the tank comes with the correstly colored wires. Thanks again, Tony"
"Well I received the tank yest
"Well I received the tank yesterday. Of the two wires one of them had a eyelet for a ground connection. I installed that one to ground. The other I hooked up to the brown near the big red connection. I have not had time to test run it because I threw a prop on the second run of the boat. The remanufacturer failed to install a cotter pin when they mounted the motor. I did not notice it when I installed the motor. They are sending me a new prop but I will find out if they are sending the rest of the hardware to install the prop. Y'all have fun, Tony"
