Re: Evinrud 225 Alarming Erratically
Ok...here we go....
There are four faults that cause the alarm to trigger:
1. Overheat, 2. Fuel restriction, 3. No oil, 4. Low oil.
There is no "smarts" to it...ie there is no computer interpreting the fault and sounding the horn. It is a very simple warning system.
The fault warnings are all triggered in the wiring of the engine by tan wires. The tan wires have colored stripes on them, tan/yellow, for instance is on the OMS pump wiring plug, and will signal a no oil condition. The tan/black is in the oil tank harness, and will signal a low oil condition. The tan/orange is in the incoming fuel line vacuum switch and will signal high vacuum in the incoming fuel line. The solid tans are present at each temp sender at the top of each head.
So, if you take ANY of those lines to ground, the associated warning horn beeps will sound.
If it were me, I would systematically disconnect the harness for each of the four conditions (one by one) and try to determine which circuit is causing the intermittent horn sounding. That MAY point to a defective sender switch that is intermittently open/closed/open as you are underway. Bad low oil switch in the tank would be high on my list....
If you cannot isolate it that way, then you are experiencing some sort of intermittent electrical short to ground on one of those tan wires in the wiring harness. If that is the case, it will be tough to find.
If you put an ohmmeter on any of these tan wires, other lead to ground, while you are underway, the ohmmeter will indicate a short to ground when the horn goes off. For example, put the ohmmeter on a tan temp wire, run the motor recreating the fault, and see if the meter fluctuates as the horn sounds. If it does, you have found the shorting circuit. If it is solid open to ground, but the horn still sounds intermittently, then it is not the temp circuit, and must be a different one. Try til you find the shorting tan wire.
I also heard somewhere that routing the tans (temp) too close to PP wiring may cause intermittent sounding of the horn, but this is way fuzzy for me, and if someone else knows for sure, please chime in.
