C
Chuck Lane
Guest
" 89 xp 200 wont idle plugs ex
" 89 xp 200 wont idle plugs extremely wet but somehow hits on all 6. Im comfortable all adj and sincs are correct except for possibly 1, Clymer says on idle adj that when all adj are done motor should idle between 500 &750 rpm in gear and throttle cam should NOT touch roller, Is this correct? The only way i can get it to idle is to adj throttle arm stop screw until it just barely cracks open the butterflies wich in turn puts throttle cam against roller then idles good and plugs are dry.Is clymer correct on this adj? "
