Evenrude 48 hp choke and fuel problems
collins24121
"Hello All,
How is it going,
"Hello All,
How is it going, this is my first time posting here and was hoping that I can get a little help with my recent purchase of a pontoon with a 1995 48 hp Evenrude it ran great until I went to fix the gas gauge that was not working. Since then these are the problems I am having.
1st problem I am having is while running at any speed I have to push in the (key)choke just so it will run faster and better, this fixes’ the problem but only for a short time.
2nd. problem is sometimes when I idle down it will cut off and can be hard to start or keep running no matter what I do with the choke. New to this 2 cycle thing and not sure how new/old the gas was when I bought this boat. I did pull the plugs and they where a little black but not to bad.
Thanks in advance for the help!"
"mr collins----your gas gauge
"mr collins----your gas gauge fix,..and your trbl's.......i cant see how they r related...it sounds like,...u need to clean/rebuild the carbs...pushing the choke,temp enrichens the eng,..making up,for clogged carbs.....however,....u need to do a full eng evaluation,first,..and always....spark,compression,..fuel.."
"Thanks for the reply, will do
"Thanks for the reply, will do on the evalation and carbs....I did find water in the fuel after I posted the question above but it still wont hurt to clean/rebuild the carb. please let me know if I should do anything more considering the water issue."
"drain all the fuel out of the
"drain all the fuel out of the tank----then treat w/a water absorbing fuel additive (the minor fuel u cant get out)....refill--and bleed all hoses to the engine,and on the engine,while u r rebuilding your carbs.."
