Evenrude 150 trim and tilt problem
S
Smielewski
Guest
"need help. 1993 evenrude intr
"need help. 1993 evenrude intruder trim will only go up not down.It was working one minute and then nothing. Read about relay switch.. sounds like my problem. Is it?? If so, where do I find relay switch for lowering engine. Also if that is the problem where do I get a relay???
Please Help
[email protected]"
" I sent you an email last nig
" I sent you an email last night re I have the same problem.I found the relays and when I reversed them as they are identical, the motor was ok.The relays on mine which should be the same as yours are at the top(right front) just behind the air box. The relays are plug in.You can't miss them,they are square and about 1" by 1".If you reverse them and the other direction works then you know which one is bad.In Canada ,they are only 22.00 from a dealer.
Alan "
