evenrude 115 ficht
had water leak from powerhead gasket to exhaust housing replaced it and also replaced water pump while at it now having issue while on muffs have no water from pee hole had gear case off 3 times to recheck water pump install still same is there something I miss when replacing gasket on power head
Did you have this resolved? Have you checked the emm that sits on top of the motor. There is a hose that flows water to cool it from one side and comes out the other. Mine was completely blocked. You'll need a long drill bit to clear it. Looking forward to hearing what happened
