Hi All,
Got a new CDI ESA (and balanced out the resistance per instructions) and a new shift assist switch, they work (engine stumbles) when I manually engage the switch with my finger, but when I move the shift lever the bracket and the switch move together and the bracket presses on the switch too late, after the gear is engaged already (can hear the gears grind). The RPMs are at 650 when I do this. I played around with the shift cable adjustments, but no luck. Any tips from the experts?
Regards.
Regards.
