I believe, actually i'm sure of the firing to be fixed as of now. Having to start the motor in with neutral throttle advanced. Then dying when returned to idle. I removed the intake manifold today and found a portion of a leaf in the in the reed valve and a couple other reed valves that seem to not close all the way and also two faulty check valves. I'm assuming that this would cause hard to start and no idle. Does this sound accurate?
