"I HAD A PROBLEM WITH ONE ENGI
"I HAD A PROBLEM WITH ONE ENGINE STALLING AFTER RUNNING ABOUT A HALF HOUR. I SWITCHED COILS BETWEEN ENGINES AND THE PROBLEM WENT TO THE OTHER ENGINE. PROBLEM SOLVED,I THOUGHT. PUT NEW AUTOMOTIVE COIL ON ENGINE TO MAKE SURE THAT WAS THE PROBLEM. BOAT RAN GREAT FOR ABOUT AN HOUR. NOW BOTH ENGINES ARE DOING IT AGAIN. THEY START TO MISFIRE AND LOSE POWER, POP THROUGH CARB AND SOMETIMES DIE COMPLETELY. POINTS,CONDENSER,CAP, ROTOR ALL NEW. THE FUEL PICKUP TUBES ARE OK. ENGINE IDLES FINE AND WILL RUN UP AROUND 1500 RPM. THEY WILL REV UP IN NEUTRAL WITH NO PROBLEM. THE COILS HAVE EXTERNAL RESISTORS. THE ONLY THING I HAVE NOT CHANGED ARE THE RESISTORS"
